when i view images in fullscreen and exit the viewer with esc then the marked image in the overview is the image i'm started. In an older version of xnview the last fullscreen-viewed image was select by exit. Can i configure this behavior in the settings?
Bye Andreas
select last viewed image
akela68
Re: select last viewed image
i found the solution. Instead use of esc i press return and the currently view image ist select in the overview.
Bye Andreas
Bye Andreas
