Links in Subfolders Not Saved Correctly in Favorites Panel (v1.7.1)
aticus
Post by aticus »
Hello!
With version 1.7.1, links within subfolders are not being saved correctly in the bookmark panel (the changes are not maintained).
1. Create a link inside bookmark panel
2. Select it, right-click, "new subfolder", give it a name
3. Drag the created link into the folder
4. The link is saved correctly in the folder
5. Close XnView and reopen it
6. The link reappears outside the folder (and the folder does not retain anything inside)
If you manually edit the "bookmark.ini" file, the changes persist when you restart the program
I'm sorry if this error has already been reported (I searched but couldn't find it)
Re: Links in Subfolders Not Saved Correctly in Favorites Panel (v1.7.1)
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
