XnView MP: XMP dialog window cannot set CountryCode
Franzi
Post by Franzi »
Using XMP metadata dialog window, there is no option to set countrycode ("Ländercode").
I can set under the menu point "Herkunft": "Ortsdetail", Stadt/Land", "Bundesland", "Land", "Bildrechte", etc, but no Countrycode ("Ländercode").
Would be great when it could be possible to set that like:
Ländercode like "DE" or "DEU".
Thanks.
BR Frank
Re: XnView MP: XMP dialog window cannot set CountryCode
you means that you can set it in 'Edit IPTC' and not in 'Edit XMP'?
Franzi
Post by Franzi »
I use XMP metadata dialog ('STRG-M'), not the IPTC dialog windows.
Nevertheless, set Countrycode in another app (like DXO), Countrycode cannot be seen neither in XMP edit dialog nor in IPTC edit dialog.
Regards
Frank
Franzi wrote: Mon Jun 03, 2024 7:55 pm I use XMP metadata dialog ('STRG-M'), not the IPTC dialog windows.
could you send me sample file XMP country code?
Franzi
Post by Franzi »
How can I send you a file?
BR
Frank
contact at xnview dot com
Franzi
Post by Franzi »
Sent.
BR Frank
Ok, i'll add it. See issue for current status and some details.
Franzi
Post by Franzi »
MANY thanks Pierre !!!
BR
Frank
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
