Viewer - tab - rework Iconify setting
XnViewMP 1.7.1
Viewer - tab
there are few issues with context menu for tab header (yellow area):
  • 'Tab settings...' opens Settings>Interface instead of Settings>Interface>Tab
  • 'Iconify tabs' - there is no need for such meta-setting in context menu, as
    - its only one of its king available and
    - can be replaced with single checkbox
    - doesn't fit well with "Close button" checkbox that should automatically uncheck and disable when Iconify is turned on, but it doesn't do that
  • rework Iconify setting
    - remove 'Iconify tabs' from context menu
    - add 'Show filename' checkbox into Settings>Interface>Tabs
  • rename
    - Close button → Show close button
    - Display → Icon
  • fix context menu
    - 'Tab settings...' should lead to Settings>Interface>Tab
Related
