Zoom Lock
rroy
Zoom Lock
Post by rroy »
Hi
Approx 2 versions prior to 1.7.2 Lock ->Zoom , was one level below under View .
Now it has been moved two levels below under Zoom.
I use it all the time. My request is to move it back up one level and or assign a hotkey.
I take bird pictures in the hundreds. So I rapidly scroll left or right with my zoom on the eye of the bird to see if it is sharp. a HUGE part of a good bird pic is if the eye is in focus. If it is not in focus, in general they are considered poor pictures.
Thanks
RR
Re: Zoom Lock
you can assign any hotkey in Settings > Shortcuts
rroy
Re: Zoom Lock
Post by rroy »
Thanks for the suggestion. I did try it and some how I can see the hotkey for Lock Zoom -^L cmd_Lockzoom but it does not work when I use it. Lock Zoom from the menu works just fine.
Thanks anyways
Re: Zoom Lock
make sure Viewer is selected in the combobox in the top left corner
