Open with -> Associated editor (F4) , not allowing MsPaint.exe as editor in Windows-11.
WiseView
Post by WiseView »
I want to use MsPaint as my editor.
The MsPaint.exe file is located in C:\Users\MyUserName\AppData\Local\Microsoft\WindowsApps\
When I try to select it, I get a message saying that “The file cannot be accessed by the system” :x
I am able to add GIMP (C:\Program Files\GIMP 2\bin\gimp-2.10.exe) as a software to open my images, but I want MsPaint. :(
Please, help!!! Thanks :wink:
Re: Open with -> Associated editor (F4) , now allowing MsPaint.exe as editor in Windows-11.
It's [system] associated editor, so in order to use F4 in XnViewMP
you need to set MSPaint as an Editor in the registry for each file type you want to edit, eg:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\SystemFileAssociations\.bmp\Shell\Edit\command]
@="\"C:\\Users\\<YOUR_USER_NAME>\\AppData\\Local\\Microsoft\\WindowsApps\\mspaint.exe\" \"%1\""
[HKEY_CLASSES_ROOT\SystemFileAssociations\.gif\Shell\Edit\command]
[HKEY_CLASSES_ROOT\SystemFileAssociations\.jpg\Shell\Edit\command]
[HKEY_CLASSES_ROOT\SystemFileAssociations\.png\Shell\Edit\command]
add_image_Edit_command_mspaint.zip
WiseView
Re: Open with -> Associated editor (F4) , not allowing MsPaint.exe as editor in Windows-11.
Post by WiseView »
Thank you very much user0
