Sorting input files
bul
Sorting input files
Post by bul »
I noticed a change in the way input files are sorted in xnconvert, it is no more done automatically.
I mean if you drag'n'drop several folders the filelist was sorted by filename regardless of its directory.
Now I have to click 2 times on "name" to sort the files ascending "the old way"...
Can you implement the old way of sorting in a future version?
And using natural sort (if not already doing it) in XnView would be nice too.
Re: Sorting input files
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
