Windows shows AVIF and HEIC files as icons and not as thumbnails
Miloiu Andrei
Hello XNView team! I like your softrware very much. However, I found some issues with it. I use XNView MP 1.7.2 64-bit and I noticed HEIC and AVIF files are shown only as icons on Windows and not as thumbnails as for JPG, ICO, BMP and PNG. The buig is reproducible on any version of Windows. I use both Windows 7 and 10.
Re: Windows shows AVIF and HEIC files as icons and not as thumbnails
XnView doesn't change the way to display thumbnail in windows explorer
Miloiu Andrei
So, do you mean the problem is from Windows? I didn't find this problem for pictures that use popular file formats like jpg, gif, png or bmp.
Kadet
Go to Microsoft Store and add this app to system: AV1 Video Extension.
Miloiu Andrei
It's now fixed for AVIF files, but not for HEIC ones.
Kadet
You have to add HEVC codec from MS Store.
Miloiu Andrei
Good! Thank you very much!
