1.7.2: Wayland connection breaks when viewport scaling takes longer than a few seconds
BloodySword
Post by BloodySword »
XnView: MP 1.7.2 - 64 bit
OS: Linux 64bit (Fedora 40)
Effect: The application crashes
1. Open a really big image while "ZOOM & MOVE" is enabled in the mouse settings
2. Click and hold the mouse button corresponding to Zoom & Move
3. Release the mouse button and keep moving the mouse
Actual behaviour (bug): The application closes / crashes :bug:
Expected behaviour: The zoom is being reset without the application crashing
Log:
kyo@bedroom-pc:/mnt/nas/commissions/Kyoudai Ken/The_Artspear/NEW Ref Sheet$ /opt/XnView/xnview.sh Kyo_Lower_Armor_Colors_WIP_SIDE_15-gpx.jpg
0.25.0 (git 2200147) - Multimedia Development Kit. Copyright (c) 2016-2024 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: Linux x86_64; Clang18.1.0 (++20240129073356+3df71e5a3f5d-1~exp1~20240129193412.14)GCC4.2.1; libc++180100; 06:19:03 Jan 31 2024
QFont::fromString: Invalid description 'ChicagoFLF,10,-1,5,500,0,0,0,0,0,0,0,0,0,0,1,Regular'
QFont::fromString: Invalid description 'DejaVu Sans Mono,10,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
QFont::fromString: Invalid description 'ChicagoFLF,9,-1,5,500,0,0,0,0,0,0,0,0,0,0,1,Regular'
==> 2.000000  2.000000  51.819671  96.000000  (1)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 200 194
libpng warning: iCCP: known incorrect sRGB profile
QObject::connect: No such slot AbstractViewWindow::onPagePrevious()
QObject::connect: No such slot AbstractViewWindow::onPageNext()
QObject::connect: No such slot AbstractViewWindow::onPageFirst()
QObject::connect: No such slot AbstractViewWindow::onPageLast()
QObject::connect: No such slot AbstractViewWindow::onUseSmooth()
QObject::connect: No such slot AbstractViewWindow::onNormalize2()
QObject::connect: No such slot AbstractViewWindow::onAlign()
MENU install : 0x1e900b0
Create window finished
==> 200
ThumbLoaderThread :: stop()
@@ BitmapResizeThread:: clear
MyView::change /mnt/nas/commissions/Kyoudai Ken/The_Artspear/NEW Ref Sheet/Kyo_Lower_Armor_Colors_WIP_SIDE_15-gpx.jpg
## Bitmap :: load 0
###### GFF:load </mnt/nas/commissions/Kyoudai Ken/The_Artspear/NEW Ref Sheet/Kyo_Lower_Armor_Colors_WIP_SIDE_15-gpx.jpg>
####LOAD </mnt/nas/commissions/Kyoudai Ken/The_Artspear/NEW Ref Sheet/Kyo_Lower_Armor_Colors_WIP_SIDE_15-gpx.jpg>  0
@@ BitmapResizeThread:: set
### resetViewport (0x1d06b80)  ==> 200 74  (44 74) 0 0
@@ BitmapResizeThread:: start  0 1 88
SORT the list...
STD::SORT... 4
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
### ThumbLoaderThread :: setFileList(1)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 1de4ae0
######ThumbLoaderThread :: forever : 1de4ae0
 ** start condition wait
### ThumbLoaderThread :: setFileList() after wait
 ** start condition wake one 2
setCurrentFilename </mnt/nas/commissions/Kyoudai Ken/The_Artspear/NEW Ref Sheet/Kyo_Lower_Armor_Colors_WIP_SIDE_15-gpx.jpg>
######ThumbLoaderThread :: forever 2 : 1de4ae0
CHECK <1>
### START 1
######ThumbLoaderThread :: start : 1     -1 -1
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
### ThumbLoaderThread :: setFileList(0)
CHECK <0>
## OPEN FOLDER
## Check folder
  ## Check companion  0
  ## Check companion ok  0
  ## OPEN DB FOLDER ok  5
  ## UPDATE DB FOLDER ok  5
  ## OPEN FOLDER ok  5
## updateLabel  5
## updateLabels ok  5
SORT the list...
STD::SORT... 4
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
## OPEN FOLDER done  6
############### UPDATE MENU ############
@@ BitmapResizeThread:: finish
### resetViewport (0x1d06b80)  ==> 1920 908  (542 908) 0 0
@@ BitmapResizeThread:: start  0 1 1084
SORT the list...
STD::SORT... 4
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
### ThumbLoaderThread :: updateFileList
### ThumbLoaderThread :: updateFileList ok
@@ BitmapResizeThread:: onThreadImageResized (85976262)
MyBitmapView :: mousePressEvent
### resetViewport (0x1d06b80)  ==> 1920 908  (9551 16000) 7631 15092
@@ BitmapResizeThread:: onThreadImageResized (85976292)
### ThumbLoaderThread :: setFileList(31)
CHECK <30>
### START 31
######ThumbLoaderThread :: start : 30     -1 -1
SORT the list...
STD::SORT... 4
  STL::SORT... 0
SORT the list... 0
SORT the list... 0
@@ BitmapResizeThread:: onThreadImageResized (85979563)
@@ BitmapResizeThread:: onThreadImageResized (85982293)
@@ BitmapResizeThread:: onThreadImageResized ok (1084 1816)
DRAW resized Bitmap  1084 1816
QMetaObject::connectSlotsByName: No matching signal for on_pbDelThumb_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_pbOptimize_clicked()
QObject::connect: No such signal QComboBox::toggled(bool)
QObject::connect:  (sender name:   'cbZoomStep')
QObject::connect:  (receiver name: 'sbZoomStep')
qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
The Wayland connection broke. Did the Wayland compositor die?
After researching the last line in the log, it seems like that while XnView is updating the zoom (which can be slow on an iGPU powered system with huge images), the message qeue of the Window tends to run full - or the connection to Wayland times out.
A solution could be to move the viewport into its own thread, so that the window thread is still responding to the display protocol.
Adding the following line before the exec command in xnview.sh, it works, but the menu has some rendering issues as well as the icons are too small on hi-dpi displays:
export QT_QPA_PLATFORM=xcb
It throws QT into X11 mode, which on a pure Wayland system uses XWayland compatibility layers.
BloodySword
Re: 1.7.2: Wayland connection breaks when viewport scaling takes longer than a few seconds
Fixed since 1.8.x
