XnView: MP 0.99.7 - 64 bit
OS: Windows 10 64bit
Checkboard setting under Settings > View ("Use checkboard pattern as background") does not respond.
Setting is turned off, but Checkboard pattern still appears in file & folder list.
1.72 64bit: Checkboard setting is broken
Volbloed86
Re: 1.72 64bit: Checkboard setting is broken
there is no functionality to change alt row colors in the app, checkboard pattern responsible for different thing
Volbloed86
What's the setting for then?
it's the checkboard used to display alpha image
Volbloed86
Ah! Okay... That wasn't clear to me.
Thanks for getting back on this subject.
