Background and transparent PNG
Gwenael Q.
Post by Gwenael Q. »
Probably missing something obvious, but I would like to display PNG with a checkerboard background everywhere in XnVMP in order to be sure of the transparent zones.
The only place I can see the checkerboard is the preview in browser mode. That's not enough.
Settings>Thumbnails allows me to select "use alpha channel" but no checkerboard seen behind thumbnails.
"Settings>View> Use checkboard pattern" is also selected
Thanks for listening
Re: Background and transparent PNG
you would like to see checkerboard in thumbnails?
