How to disable the blurry thumbnails?
yutils
Post by yutils »
Is there a way to get the thumnails nice as crisp, like they are in XnView Classic.
In MP they are horribly blurry.
It might work fine for jpegs but for screenshots (like png), you cannot see very well what is in the images.. vs the nice sharp thumbnails of Classic.
Kadet
Re: How to disable the blurry thumbnails?
Post by Kadet »
Make bigger x y thumbnails in two placed in settings.
Then rebuild the database of the thumbnails.
yutils
Post by yutils »
I have them pretty big already.. 384x288.
Rebuilding does nothing visually to them.. still blurry.
I think it is due to applying a kind of filter to it that would make photos look great but not screenshots or drawings. I forget the technical term for this. So I'm wondering how to change this kind of image rendering algorithm.
Kadet
Post by Kadet »
Check what You have setting in thumbnails.
If You use set inbuilding thumbnails set too make thumbnails if is a smaller. Or uncheck inbuilding thumbnails option.
And then of course rebuild database.
