change labels of the Similar files search results
therealgord
Post by therealgord »
I have looked for but cannot find a way to do this in the settings, I may be missing something. Can the labels in the Find similar files search results window be changed? I would like to add some EXIF fields like Date created, Date digitized, etc. Thanks.
Re: change labels of the Similar files search results
currently not possible
