Slideshow settings OK button does not function correctly
Altech
Post by Altech »
Subject: 0.99.7: <Slideshow settings OK button issue>
XnView: MP 1.7.2 - 64 bit
OS: Windows 11 - 64 bit
<OK button does not react correctly to accept Slideshow settings screen>
Effect: <Upon attempting to increase slideshow transition time to 4.00 secs; OK button does not react and new transition time is not saved>
1. <Go to Tools - Slideshow...>
2. <Make a change and/or simply click on OK button>
3. ...
Actual behaviour (bug): <Settings screen does not reset> :bug:
Expected behaviour: <That amendment screen should be saved/accepted thereby returning to general Toolbar view>
Re: Slideshow settings OK button does not function correctly
i can't reproduce, when pressing OK, slideshow is started with correct settings
Altech
Post by Altech »
That is very odd that it appears to work okay for you as I have attempted that change to Slideshow settings again today and the curious thing is that the 5.00 seconds value I entered previously is there to be seen but the slideshow itself continues to change the photo every two seconds which was the default setting. Plus, I still cannot clear that settings screen with the OK button or by pressing Enter on the keyboard. The other three buttons on that Slideshow settings dialog box are responding fine. Very strange!
which settings in slideshow do you have?
Altech
Post by Altech »
This is my Slideshow settings screen and the OK button which is not responding whereas the other buttons are fine.
could you send a screencast to show the problem?
Altech
Post by Altech »
I want to attach a short screen recording as requested but having created four progressively shorter videos, whereby the latest was 6 seconds, (24.2MB) XnView is still telling me that the file is too large. What is the limit here? It would be too short to see me even just hitting the "OK" button a couple of times without response!
you can send it by mail
Altech
Post by Altech »
Hi Pierre
I am not aware of an email address so I won't trouble anyone further as my 'OK' button in that Slideshow settings box simply does not want to function, even though every other button I click on does work normally.
I don't use the slideshow option often so I can live with not being able to change those settings. Thanks anyway.
