AVIF - cannot write EXIF data?
duittenb
Post by duittenb »
Team,
First of all: in my quest to "fix my photos" - things like dates/formats/locations/etc XnView has been very valuable, good job!!
When using the AVIF format I noticed that
- JPGs converted to AVIF have GPS and time metadata in the Exif fields
- AVIFs where you edit the metadata Timestamp or GPS will not change.
So it looks like that the "metadata Timestamp or GPS" feature does not support updating AVIF exif data.
Is that a known limitation or a bug?
XnView MP 1.7.2 64-bit (MacOSX) - Libformat 7.180
Thank you!
Re: AVIF - cannot write EXIF data?
yes currently, you can't edit EXIF on AVIF
duittenb
Post by duittenb »
Are there any updates on the AVIF metadata edit support?
The past 2 years all of my photos are AVIF and I really really miss using XnViewMP!
What (seems to) works?
- Convert JPG with location, time etc set. to AVIF
What fails?
- Edit GPS location of AVIF or WebP --> not updated
Any workarounds?
please use latest version
duittenb
Post by duittenb »
xnview wrote: Tue Jan 20, 2026 9:55 am please use latest version
Thank you for the quick response!
Just ran the update from 1.9.9 to 1.9.10 (MacOS) and tested:
- Image: iPhone 13 HEIC image with GPS data
- convert to AVIF: gps data transferred = OK, expected.
- convert to WEBP gps data transferred = OK, expected.
Tested with both of these images:
- Right click photo, metadata, edit GPS
- Paste location copied from another photo or Google maps
- Write
Result: GPS data not updated (checked GPS data via several applications, but it has not changed)
Also restarted XnViewMP and laptop.
UPDATE
When starting XNview via commandline I noticed the following logging:
Build for: macOS110000/26.2.0 25.2.0 16KB ARMv8 AArch64; libc++190102; Apple Clang17.0.0 (clang-1700.0.13.5); 03:47:27 Sep 30 2025.
==> 1.000000  1.000000  110.000002  72.000000  (0)
dlopen: rwz_sdk
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/rwz_sdk.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/rwz_sdk.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/rwz_sdk.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/rwz_sdk.dylib' (no such file)
dlopen: libwebp
dlopen: libJPEGXL
dlopen: openjp2
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
dlopen: libflif
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/libflif.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/libflif.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/libflif.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/libflif.dylib' (no such file)
dlopen: AVIFlib
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/AVIFlib.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/AVIFlib.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/AVIFlib.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/AVIFlib.dylib' (no such file)
dlopen: libJPEGXL
dlopen: gpr
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/gpr.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/gpr.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/gpr.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/gpr.dylib' (no such file)
dlopen: libora
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/libora.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/libora.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/libora.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/libora.dylib' (no such file)
dlopen: packJPG
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/packJPG.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/packJPG.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/packJPG.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/packJPG.dylib' (no such file)
dlopen: clip
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/clip.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/clip.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/clip.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/clip.dylib' (no such file)
dlopen: clip
dlopen: xisf
    ->  dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/xisf.dylib, 0x0001): tried: '/Applications/XnViewMP.app/Contents/MacOS/Plugins/xisf.dylib' (no such file), '/System/Volumes/Preboot/Cryptexes/OS/Applications/XnViewMP.app/Contents/MacOS/Plugins/xisf.dylib' (no such file), '/Applications/XnViewMP.app/Contents/MacOS/Plugins/xisf.dylib' (no such file)
----> 0 0
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 2067 1292
A quick check of the Plugins folder:
$ ls -la /Applications/XnViewMP.app/Contents/MacOS/Plugins
total 23584
drwxr-xr-x@ 9 my_username  admin      288 Jan 15 09:02 .
drwxr-xr-x@ 6 my_username  admin      192 Jan 15 09:03 ..
-rw-r--r--@ 1 my_username  admin  1394960 Jan 15 09:02 libheif.dylib
-rwxr-xr-x@ 1 my_username  admin  1428512 Jan 15 09:02 libJPEGXL.dylib
-rwxr-xr-x@ 1 my_username  admin  6438944 Jan 15 09:02 libOpenEXR.dylib
-rwxr-xr-x@ 1 my_username  admin  1170672 Jan 15 09:02 libwebp.dylib
-rwxr-xr-x@ 1 my_username  admin   119056 Jan 15 09:02 libwebpdemux.dylib
-rwxr-xr-x@ 1 my_username  admin   171872 Jan 15 09:02 libwebpmux.dylib
-rwxr-xr-x@ 1 my_username  admin  1337424 Jan 15 09:02 openjp2.dylib
Could it be that MacOS does not have these libraries by default and that XnView does not provide them during install?
right on MacOS, we need to update Exiftool...
duittenb
Post by duittenb »
xnview wrote: Wed Jan 21, 2026 8:08 am right on MacOS, we need to update Exiftool...
UPDATE: created separate thread for this as it IS a different issue :-)
viewtopic.php?t=51048
With the latest version I run into a HEIF library issue (wrong name?)
Launch Xnviewmp from command-line: /Applications/XnViewMP.app/Contents/MacOS/xnviewmp
0.35.1 (git 652c616) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: macOS110000/26.5.1 25.5.0 16KB ARMv8 AArch64; libc++200100; Apple Clang17.0.0 (clang-1700.4.4.1); 07:39:03 Dec 30 2025. Mac14,15
HEIF: dlopen(/Applications/XnViewMP.app/Contents/MacOS/Plugins/libheif.dylib, 0x0001): Library not loaded: @rpath/libde265.0.dylib
  Referenced from: <4F1961DD-8538-3144-A489-4B65D60F0A52> /Applications/XnViewMP.app/Contents/MacOS/Plugins/libheif.dylib
  Reason: tried: '/Applications/XnViewMP.app/Contents/Frameworks/libde265.0.dylib' (no such file), '/Applications/XnViewMP.app/Contents/Frameworks/libde265.0.dylib' (no such file)
 Version : 26 5
Created symlink to the file where it expects it to be
sudo ln -s libde265.dylib \
Now starting xnviewmp works without errors.
