Hi, there!
MP 64 on Win10 64
I use "Show Tag Box" and tag ONE of severel images in a folder. After that I use "Move to..." to move the image to a different folder. In that case with only ONE tagged image the dialog "move selected or tagged files" does not come up and the selected and not the tagged image is moved. Same with "Copy to...". When I tag one image but have several images selected the dialog come up as normal.
If I tag at least two images all is fine.
Best regards
RandL
1.7.2 (and before) Using Tag-Box with only ONE taged image
RandElement
Re: 1.7.2 (and before) Using Tag-Box with only ONE taged image
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
