XnViewMP 1.7.2 64bit
Browser/Viewer - open with associated editor (MSPaint in my case)
path param is truncated at the first space
0. make the following file/folder: "c:\a b c\a b c.png"
1. open file in Viewer or select in Browser, press F4
Paint "file not found" error message appears, showing the path truncated after the first space
(c:\a.png)
there is no such issue when using Edit command in win file explorer
1.7.2 - viewer/browser - open with associated editor - path truncated at space
Re: 1.7.2 - viewer/browser - open with associated editor - path truncated at space
no problem here, Paint is opened correctly
