Cannot figure out how to use Name template
fabfrances
Post by fabfrances »
HEllo,
Very new to XNView, I wanted to use the rename function to rename pictures with format "YYYYMMDD_HHMMSS"
So basically using the exif data from the picture formated as:
- Year on 4 digits
- month on 2 digits
- day on 2 digits
- underscore sign _
- hour on 2 digits
- minutes on 2 digits
- seconds on 2 digits
Then leave the extension as it is.
And I cannot figure out how to enter the name template, if I enter YMD_HMS, it is just showing name as YMD_HMS
I have tried to put brackets like [] and {} but it is just showing the same with the brackets..
Thank you for your help in advance
Kind regards
fabfrances
Re: Cannot figure out how to use Name template
Ok I have found out finally...
So in case someone needs it, the naming is working with "variable" first as for example "Creation Date", then the format in the below form:
{Creation Date [Ymd_HMS]}
Doing so it will take the exif data of when the picture was created, then format it by your template
Hope this helps
Thanks
