Add option to keep transparency when converting png images to lossy webp
abadyr
Post by abadyr »
It would be a checkbox in the parameters of the webp compression format.
If XnView MP uses cwebp to convert images into webp, it could work for example adding the command "-alpha_q 100" or "-alpha_method int 0".
So a complete command would be something like that, plus any additional chosen options, again assuming MP uses cwebp:
