I just noticed that JXL files are supported and work correctly in XNViewMP 1.7.2 under Windows 11.
The same version (XNViewMP 1.7.2; Flatpak installation) does not open JXL files under Linux Mint 21.3. There is no entry in 'Settings-Formats'. Does this mean that JXL file format is not supported under Linux?
Regards,
Janko
JXL files do not open in Linux Mint
Janko
Regards,
Janko
Janko
Re: JXL files do not open in Linux Mint
Currently JXL is supported on Windows & MacOS, soon on linux
Janko
Thank you very much for your reply, and of course for the fantastic software!
Looking forward to linux support for JXL files.
Regards,
Janko
Regards,
Janko
Regards,
Janko
Janko
Janko
I just noticed that the latest version of XNView MP (1.8.2) is opening JXL files.
Thank you!
Regards,
Janko
Thank you!
Regards,
Janko
Regards,
Janko
Janko
