XnConvert 1.100.1
os: macOS 14.1.2
converting a jpg to avif.
error massage:
/Users/vornamenachname/Desktop/bbb/test.jpg : loading
/Users/vornamenachname/Desktop/bbb/test.jpg 1920x1200x24 : loaded
/Users/vornamenachname/Desktop/bbb/test-Xn.avif : not a picture
Saving error(s):
Input files: 1
Extracted pages: 1
New files: 1
Total Duration: 0 second(s)
AVIF export error
Re: AVIF export error
yes known issue
allbutone
Is there any progress with the problem?
IconRedesigner
I have the same issue trying to convert from PNG or WEBP.
XnConvert Version 1.105.0 - x64 (Apr 16 2025) - Libformat version 7.221
which error do you have?IconRedesigner wrote: Tue Jun 24, 2025 8:04 pm I have the same issue trying to convert from PNG or WEBP.
IconRedesigner
Sorry Pierre, just noticed your question.xnview wrote: Thu Jun 26, 2025 12:04 pmwhich error do you have?IconRedesigner wrote: Tue Jun 24, 2025 8:04 pm I have the same issue trying to convert from PNG or WEBP.
In the current ↑ version, PNG to WEBP works fine,XnConvert Version 1.106.0 - x64 (Oct 12 2025) - Libformat version 7.228
but PNG to AVIF still doesn't work:
On the other side, AVIF support is still very limited, so why bother?Started at: 2026.04.12 15:52
/Path/to/Image.png : loading
/Path/to/Image.png 1080x1080x32 : loaded
/Path/to/Image.avif : not an image
Saving error(s):
/Path/to/Image.avif
Input files: 1
Extracted pages: 1
New files: 1
Finished at: 2026.04.12 15:52
I just wanted to see how good that format is.
it's a known issue on Mac Intel
