Bug report:
______________________________________________________
XnView: MP 1.7.2 - 64-bit
OS: Windows 11 - 64-bit
XnView Mp does not play the animated gifs inside the archive files (zip, rar)
Effect: Animated gifs show as static images
1. Browse a folder A with zip files consisting of animated gifs.
2. Double click to open the zip file from the XnView MP.
3. Double click to open a gif image inside the zip file.
Actual behaviour (bug): See the static image instead of an animated gif playing. There is no problem if the same gif files are inside a folder instead of an archive file.
Expected behaviour: Gifs should be playing instead of showing static image.
						1.7.2: Animated gifs fail to play
