Basically what the title says. I need to format the info box content for fullscreen view, but every single tag character makes the info box wider. Using XnView MP 1.7.2.
Cheers!
HTML tag characters count towards info box width in fullscreen
Sprawl2459
Re: HTML tag characters count towards info box width in fullscreen
how to reproduce?
related
Info - add 'HTML only' mode
content takes less than half of info box, but unfortunately
its width is calculated based on symbols quantity in the longest string, in our case - 1st (red)
2. add line breaks at the blue lines
info box will shrink
need a new "html only" mode, not this weird mix of text and html tags
1. use code from post above (set border=1 to show where content ends)
Sprawl2459
I couldn't have described it any better. In fact, I couldn't have described it as well as you. : )
Could you send me the text used?user0 wrote: Tue Jul 02, 2024 9:31 am 1. use code from post above (set border=1 to show where content ends)
