XnView: MP 1.7.2 64 bit
OS: macOS Sonoma 14.5 on an ARM (M2 Pro) MacBook Pro
When trying to save an image using JPEGLI encoder, I always get a failure; the following, rather unhelpful, message is shown in a dialog window: "An error occurred during saving!". If there is a way to generate a more detailed log, please let me know, and I'll test and post here.
I formerly mentioned this issue in this thread without noticing it's actually NConvert forum, not XnView(MP).
1.7.2: saving to JPEG format using JPEGLI encoder causes error
Re: 1.7.2: saving to JPEG format using JPEGLI encoder causes error
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
Thanks Pierre, it works now. XnViewMP is the tool!
