1.7.2 import no sidecar / .xmp file
Flyk3
Post by Flyk3 »
if you have activated sidecars for videos and categorise a video, XMP automatically creates an .xmp file and saves the categories there.
If you now move the video including the .xmp to a new folder in Windows Explorer, XMP ignores the content of the .xmp file. In older versions, the categories were imported. This is a catastrophe for me because I have moved hundreds of videos and nothing is categorised any more. :(
We had the same problem 2 years ago: viewtopic.php?f=104&t=43341
Categorise a video in folder 01:
Move video and .xmp to another folder:
XMP don't import the saved categories:
For testing purposes, I started with fresh settings and only changed attached settings.
Re: 1.7.2 import no sidecar / .xmp file
Strange, i've tried but categories are imported. Please send me the .xmp and your xnview.ini
Flyk3
Post by Flyk3 »
Sure, please find these attached.
I also tested it with the old version 1.4.0, which fixed the problem 2 years ago and it doesn't work there either. I first deleted the XnViewMP folder in Roaming, uninstalled the program and reinstalled it. I also deleted the sidecar. Same problems as with 1.7.2
Video are disabled in 'Custom filter', so files are not readed
Flyk3
Post by Flyk3 »
I have not disabled video in any custom filter. The settings come from a fresh installation. How can I reactivate this?
Flyk3 wrote: Sun Aug 11, 2024 6:08 am I have not disabled video in any custom filter. The settings come from a fresh installation. How can I reactivate this?
Settings>View>Filter
Flyk3
Post by Flyk3 »
Works now.
However, this option should be better explained. I'm also wondering why it was set this way. I did not set this and after deleting options XnView MP automatically creates these settings again.
Flyk3
Post by Flyk3 »
Hi Pierre,
the problem has returned and I have noticed that the problem has only occurred with folders containing a large number of video files.
I didn't have the problem with the ‘vanilla’ settings. So I searched for all the settings that I had changed manually. After a few hours of searching and testing, I finally found the problem:
If ‘create thumbnails for the whole folder’ is disabled, XMP only creates the thumbnails for the first two pages of the folder view and imports the sidecars. If you then scroll down further, XMP creates more thumbnails, but ignores the content of the sidecars.
For testing purposes, I have created a 30-frame video (without copyright), copied it 400 times including the .xmp files and packed it into the attached archive.
If you then deactivate ‘create thumbnails for the whole folder’, open the folder in XMP and wait until the thumbnails of the first two pages have been created, you should be able to reproduce the problem by scrolling down.
Post by michel038 »
Flyk3 wrote: Wed Aug 21, 2024 8:40 pm After a few hours of searching and testing, I finally found the problem:
I admire the perspicacity of your research and the precision of the results you have obtained. If everyone on this forum worked like you, we'd save time !
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
