How to remove the blue background for transparency
Re: How to remove the blue background for transparency
Could you post an example file, not a subject I can help with myself, though.
Realistically, you are most likely to obtain the answer by searching the forum, particularly if you include 'XnTriq' as a search term, or if necessary by searching online for the general steps in any software, and then apply them in XnView MP... :wink:
AnibalDickson wrote: Thu Oct 03, 2024 10:58 am If you're processing a large number of images and require a quick solution, an online tool may be the most efficient.
Why more so than a local tool? :wink:
