1.7.2 appimage on debian.
How do I re-read the xmp of an image already in xnviewmp?
The colour labelsand ratings were changed in ART. It's saved in the xmp. I checked the xmp file with vim.
"View > Update catalog from files" does NOT change the colour labels nor the ratings in xnviewmp.
Any setting that I'm missing?
Thanks
How to re-read XMP
Re: How to re-read XMP
'Update catalog from files' should work. do you use sidecar?artsi wrote: Thu Aug 08, 2024 7:50 pm "View > Update catalog from files" does NOT change the colour labels nor the ratings in xnviewmp.
