XnView: MP 1.7.4 64 bit
OS: Windows 10 64 bit
24bpp RGB cur files display with reversed channel order (blue and red are switched) and without transparency. Please see attached images. Ico and cur files are similar, so the display behavior of the two can be compared.
1.7.4 Cur 24bpp RGB Color Channels & Transparency
jbehreandt
Re: 1.7.4 Cur 24bpp RGB Color Channels & Transparency
please send us some sample files
jbehreandt
Sample files are online at this repo: https://github.com/behreajj/AseIcoExpor ... in/samples
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
