Add Subject Distance to info overlay.
FKCapitalism2
Post by FKCapitalism2 »
Inside Settings > View > Info could you add option to display EXIF tag
[EXIF:Camera] Subject Distance : 0.2111 m
Right now there are only two options available from Exif Image tab neither one is displaying above mentioned value.
  • {EXIF:Subject Distance}
  • {EXIF:Subj. Dist. Range}
Re: Add Subject Distance to info overlay.
please send us a sample file?
rakgupta1
Post by rakgupta1 »
Would also request this feature. File attached - it has the "subject distance" in the EXIF data
