Info Panel on Full Screen View
irhorwood
Post by irhorwood »
Hi Guys
How do you remove the info panel from full screen view please? It appears in the top left hand corner in grey.
I have been through settings and cant find the switch to toghle it off.
Mac OS Sonoma and Windows 8 🤭
Thankyou and Kind Regards
Ian
Re: Info Panel on Full Screen View
irhorwood wrote: Mon Aug 19, 2024 9:45 am How do you remove the info panel from full screen view please? It appears in the top left hand corner in grey.
The keyboard 'i' key should toggle it on and off... :D
irhorwood
Post by irhorwood »
Hi cday,
Brilliant Thank you
Kind Regards
Ian
