Image Resize, one image- multiple sizes
StevieCalista
Post by StevieCalista »
Hi there. I've uploaded an image and would like to resize it to about 12 different sizes. So one image and multiple sizes. When I set up an action to do that it only saves one file?
What am I doing incorrectly?
Re: Image Resize, one image- multiple sizes
StevieCalista wrote: Mon Aug 19, 2024 6:46 pm Hi there. I've uploaded an image and would like to resize it to about 12 different sizes. So one image and multiple sizes. When I set up an action to do that it only saves one file?
The output file size will always be the result of applying each resize action successively, outputting loaded files to multiple sizes isn't currently supported although it has been requested periodically, usually for web image use. I have in the past suggested a possible modified interface that might be used, but implementing it would require clear thinking and be a fairly significant undertaking.
At present the only alternatives are to use multiple batch convert runs with different saved scripts loaded, multiple software instances, or an NConvert command line batch file that processes each input file multiple times to output the required image sizes.
