There used to be a way to configure different external programs to send images to from XnView. I believe it resided in the Tools* menu. But I can't find it any more.
The external programs I had previously configured can still be invoked via keyboard shortcut, and in the xnview.ini I can still find the section "OpenWith". I guess by adding a program here I could still reconfigure the feature, and I guess reordering the entries here affects the keyboard shortcut. But I would really like to have the menu entries back because I don't remember all seven entries by heart to invoke them with the according shortcut.
As long as there is no UI for configuration: XnView seems to use an encoding for umlaut characters that I don't know so far. Is it documented anywhere?
Best regards
Joachim
*(I use the UI in German. I guess the "Werkzeuge" menu is "Tools" in English.)
"OpenWith" feature - where has the configuration UI gone?
jotess
Re: "OpenWith" feature - where has the configuration UI gone?
Since last version File> Open with>Configure...
Catalogage avec XnviewMP :
jotess
