1.7.2 - viewer - single instance - issue opening multiple files
XnViewMP 1.7.2 64bit
Viewer
issue with opening several files in single instance mode
0. run app with default settings
1. goto Settings > General > General tab
- ☑ Allow only one instance
- Save session on program exit - Never
- press OK
2. close app
3. select 3 files in win file explorer and press Enter
sometimes only 1 or 2 images are opened (repeat steps 2,3 to reproduce)
expected behviour
all selected files should be opened as tabs
also make sure it works correctly with "Save session on program exit - Always"
Related
Re: 1.7.2 - viewer - issue opening multiple files in single instance mode
'Interface>Drag&Drop: Open single viewer tab' is enabled?
☐ Drag&Drop: Open single viewer tab (default state)
enabling it has no effect - issue remains the same (repeat steps ~10-20 times)
do you reproduce the problem by drag&drop 3 files on XnView's icon?
no issue when files drag&droped on xnviewmp.exe - it always opens all 3 files in 3 tabs
user0 wrote: Tue Oct 01, 2024 8:49 am no issue when files drag&droped on xnviewmp.exe - it always opens all 3 files in 3 tabs
Really strange, it's the same entry point.
