I've just got a new laptop and the installed the latest version of XviewMP.
I noticed that the "up one level" entry in the file list is nowhere to be found (screenshot from 0.94.1).
Is there a way to add it back to newer versions of XviewMP? I can't seem to find anything in the options.
I know I can hit backspace to go back one level but I still prefer to have the option in the UI.
Thank you.
"Up one level" missing in newer versions?
briareos_kerensky
Re: "Up one level" missing in newer versions?
do you have enabled 'parent folder' in Settings>Custom filter?
briareos_kerensky
Completely missed that! Thanks.
