Thank you for XnvIewMP version 1.80 with wonderful speed improvements in JPEGLI (=latest JPEGLI Version 0.10.3) and other libraries (latest HEIF, WEBP, etc.). You did a good job! Thank you!
I tried the film simulation function from menu.
I chose a film simulation e.g. Gotham and Intensity 100.
Then I saved it as a preset 'Black&White'.
After that I closed the dialog and start it again with another picutre.
I load the previously saved preset 'Black&White'.
The preset set the intensity to 100, but did not choose the film simulation 'gotham'.
1.80 - film simulation - presets do not completly saved
masterjp
Re: 1.80 - film simulation - presets do not completly saved
