THANK YOU for the Linux version(s) of XnView!
A Demon
Post by A Demon »
I would just like to say THANK YOU very much for the Linux version(s) of XnView. (Of course thank you for the Windows version(s) as well)
I just made the switch from Windows to Linux (after trying out several distros for several months and finally deciding on one of them and sticking with it) and in the past the image viewers for Linux seemed to always be missing something, in my opinion of course. But now that I'm using XnView on my Linux box, I am filled with joy! It's awesome! Thank you VERY much for making this wonderful program available for Linux. I hope you continue to make future versions for Linux.
I will tell as many other Linux users as I can about XnView for Linux! :)
P.S.: When I used to use Windows, I used Irfanview until I found XnView. I much prefer using XnView.
You (the author of XnView) are awesome! :)
THANK YOU! :) :) :)
Re: THANK YOU for the Linux version(s) of XnView!
A Demon wrote:... I would just like to say THANK YOU very much for the Linux version(s) of XnView. (Of course thank you for the Windows version(s) as well) ...
Thanks!
