1.8.0 Doesn't open AVI files
Odd
Version 1.7.2 can display video clips in .avi format. Version 1.8.0 cannot.
Re: 1.8.0 Doesn't open AVI files
could you post a sample?
Odd
Sorry for taking so long to reply.
The attached screen dumps show XnView MP and XnView Classic (latest versions, installed today!), both with the same file selected.
Classic can show the first image of the .AVI file, MP cannot. Classic can run the video in the preview pane, MP cannot.
Neither of them can show .MP4 files in the browser.
Wanted to attach the .AVI file in the example, but I get the error message "Invalid file extension: 2024-05-03_01-47-36.AVI".
File up to 2MiB can be attached if placed in a ZIP, for larger files a download link is usually best, provided it will remain valid for long enough for Pierre to find it.Odd wrote: Sun Feb 09, 2025 3:41 pm Wanted to attach the .AVI file in the example, but I get the error message "Invalid file extension: 2024-05-03_01-47-36.AVI".
VictorVG
It is possible that in your case it is either the MS AVI V2 format or the file is damaged when encoding. Try to open it using the MediaInfo V24.12 utility (it currently gives the maximum data volume) and copy its text report here and we will all see what you met together.
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
Odd
Since the file CAN be viewed with XnView classic it's unlikely that it is damaged. Anyway, here is the text report from MediaInfo:
General
Complete name : M:\Viltkamera\2024-05-03_01-47-36.AVI
Format : AVI
Format/Info : Audio Video Interleave
Format settings : BitmapInfoHeader / PcmWaveformat
File size : 66.0 MiB
Duration : 10 s 0 ms
Overall bit rate : 55.4 Mb/s
Frame rate : 20.000 FPS
Video
Format : JPEG
Codec ID : MJPG
Bit rate : 55.1 Mb/s
Width : 2 688 pixels
Height : 1 520 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.674
Stream size : 65.7 MiB (99%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 1 channel
Sampling rate : 16.0 kHz
Bit depth : 16 bits
Stream size : 312 KiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 200 ms (4.00 video frames)
Interleave, preload duration : 200 ms
General
Format : AVI
Video
Format : JPEG
Codec ID : MJPG
Color space : YUV
Bit depth : 8 bits
Audio
Format : PCM
Codec ID : 1
Bit rate : 256 kb/s
Bit depth : 16 bits
Odd
I just discovered than XnView has an option in the settings to display thumnails for video files, which by defautl is switched off!!!
Which moron made that the default setting? And why hasn't anybody from the bug handling team mentioned it?
For the benefit of anybody else who might be reading this and has the same problem:
Go to Settings - File list - Custom filter and activate "Show as thumbnail" for Video.
This bug report can be closed.
