RC1: Minor: Batch scanning dialog improvements
Dreamer
Post by Dreamer »
#1: Options button doesn't focus to appropriate format, as in Batch convert.
#2: If "Save as multipage TIFF" is enabled, Format should be greyed out, or better, changed to TIFF.
XnView 1.82 <x>
Dreamer
Re: RC1: Minor: Batch scanning dialog improvements
Post by Dreamer »
Dreamer wrote:#1: Options button doesn't focus to appropriate format, as in Batch convert.
#1 - fixed
#2 - not fixed
And #3 - format list should be shown from the beginning, or at least scrolling with mouse wheel could work, because now there is no advantage that some file types are on top. Try to select TIF and then scroll with a mouse wheel and select JPG. This 'bug' is also in other dialogs, e.g. Batch convert, Save as.
BTW " - - - - - " is missing in Save as dialog.
Dreamer wrote: And #3 - format list should be shown from the beginning, or at least scrolling with mouse wheel could work, because now there is no advantage that some file types are on top. Try to select TIF and then scroll with a mouse wheel and select JPG. This 'bug' is also in other dialogs, e.g. Batch convert, Save as.
I don't have this problem... And i have '-------' in format list
Olivier_G
Post by Olivier_G »
For #3, I have:
- wheelmouse works
- separator "-- -- -- -- --" is shown (but it selects the previous filetype when you select it. It shouldn't change selected filetype)
- but the list/scrollbar starts at selected filetype instead of starting from top.
Olivier
Dreamer
Post by Dreamer »
- wheelmouse works
This is probably depending on mouse type / software... We need more testers.
Strange it works here too, now.
Dreamer
Post by Dreamer »
#1 - fixed
#2 - not fixed
#1 - fixed
#2 - fixed
#3a - "format list should be shown from the beginning" - not fixed
#3b - "scrolling with mouse wheel could work" - not fixed
BTW - fixed
