Dear Sirs
Can MP and Classic versions be installed in the same machine ?
Tks
Rui
Install XnView MP and XnView Classic on same computer?
Passaro
Re: MP and Classic
Yes, if you wish, but 'MP is now the recommended software with a number of advantages and still under active developments...Passaro wrote: Thu Sep 05, 2024 3:06 pm Can MP and Classic versions be installed in the same machine ?
Passaro
Re: Install XnView MP and XnView Classic on same computer?
Tks a lot. I will check. I want to check something related to the size of the image when we search for duplicates.
I will check
Tks
Rui
I will check
Tks
Rui
