Tag features missing from 1.8.0
bnewlove
Post by bnewlove »
All the "tag" features appear to be missing from 1.8.0, i.e. you cannot view all tagged files, remove all tags etc. The only tag related feature is in the filter menu, but that only applies to the current folder. Is this an oversight or by design? If by design, please explain what features replaced the tag features as I use them a lot. Brian Newlove
Re: Tag features missing from 1.8.0
check Metadata menu
bnewlove
Post by bnewlove »
Oops. My bad. Thank you.
