New versions are worse
zstoja
Post by zstoja »
First of all, I use list of files left side. If I resize the app, left panel is resized, must resize picture panel (right).
Another problem. More clicks than before. Keep in mind that you design app with less clicks, not more.
Old versions were better and I will remove new one.
Some previuos versions: One click: Browser-Viewer - Fullscreen.
Now I have to use double click for the same.
In fact, I need, but it is simple and fast:
One click on file in left panel, picture is opened in right panel with all menu/toolbar buttons as double click.
I do not need to close tab now, just click another file in left panel.
Tabs must be an option.
Do not complicatre life if it is not impoortant.
Anothe: Favorites (folders) must be option to be on top of left panel, but not whole width of the app., because picture can be higher. Monitor is wide, not so high.
A lot of softwares are "imptroved" just to say that it is different. Do not be in that way.
Re: New versions are worse
old versions are the same, or do you talk about XnView Classic?
