[LIBRAW 0.21.2] can add laster version?[CLOSED]
manuel_songokuh
Post by manuel_songokuh »
hi
i see xnviewmp 1.8.0 using old version of LIBRAW 0.21.1 (release from Jan 5, 2023) instead last version:
LIBRAW 0.21.2 (release from Dec 19, 2023)
can add libraw 0.21.2 to xnviewmp?
Last edited by manuel_songokuh on Fri Sep 27, 2024 12:13 pm, edited 1 time in total.
Re: [LIBRAW 0.21.2] can add laster version?
yes
manuel_songokuh
ok,
i did testing: binary for linux: from file libraw.so.23.0.0 to liblibraw.so, create symbol-link: liblibraw.so.1 from liblibraw.so) result echo error: missing lib: jasper, i add lib new jasper, but result error, so not work.. so i will wait to 1.8.1 add libraw 0.21.2 ok?
manuel_songokuh
Re: [LIBRAW 0.21.2] can add laster version?[CLOSED]
i close this topic because that is update next version 1.8.1
thank you Pierre!!!
