Hi!
Is there any way to add an icon to the toolbar the action of "open with the associated program" directly (not the icon of the "open with" menu)? If the option does not exist, could it be raised as a suggestion or request?
Thanks in advance!
adding a icon for "open with the associated program" in the toolbar
aticus
Re: adding a icon for "open with the associated program" in the toolbar
you can add a new '-- COMMAND --' to toolbar
aticus
hi!
In that way, I can choose an .exe (in Windows) so that the file opens with a specific program, but I'm referring to opening it with the associated program in each case (for each file extension).
