Using "Fit image to window" and an image that is smaller than the default window, I've tried Alt+/, Shift+/ (?), period. Nothing works, but the menu selection does. The existing default "/" for "Fit image to window, large only" works fine.
This is on a GPD Win Max 2.
1.8.0 - Cannot set keyboard shortcut for "Fit image..." options
Stone-D
Re: 1.8.0 - Cannot set keyboard shortcut for "Fit image..." options
which shortcut do you have added?
Stone-D
I've tried "?" (Shift-/) and Alt-/ as those would be the easiest to remember since I use the default "/" a fair amount to resize large only.
i've tried with 'K' key and it works
Stone-D
Very odd. I've just tried with k as well and it's not working.
Are the new shortcuts supposed to appear in the menu as well? They're not showing up for me, even after restarting XNView MP.
you change the shortcuts in browser not Viewer
Stone-D
... oh wow. Sooooo sorry, haha. I still mostly use XNView Classic so I'm still unfamiliar with MP.
