1.8.0: Modify the image name after entering the Chinese "耀", the software directly flashes out.
Kenneth
Post by Kenneth »
1.8.0: After changing the name of a picture or entering the Chinese character “耀” when searching for a picture, the software directly flashes back.
XnView: MP 1.8.0 - 64 bit
OS: Windows 11 23H2 - 64bit
<When you change the name of a picture or search for a picture in the software, just type in the Chinese character “耀”, and the software will flash back directly.>
Effect: <XnView crashes>
Kenneth
Re: 1.8.0: Modify the image name after entering the Chinese "耀", the software directly flashes out.
Post by Kenneth »
Copying and pasting is no problem, typing directly crashes 100%.
lffs
Post by lffs »
f28c37df-7d5a-43c6-a349-91edacd2ae7a.dmp.zip
gif motion picture. Please click to view
i' ve tried to paste but no crash.
lffs
Post by lffs »
xnview wrote: Sat Sep 14, 2024 1:30 pm i' ve tried to paste but no crash.
It will only crash if you use an input method. You need to add Chinese language and add Microsoft Pinyin Input Method keyboard, switch to Chinese Input, then type "yao" and select the character "耀". (Use the Page down/up keys to turn the page and find the character.)
The program will crash when there is only one "耀" character in the input box.
Kenneth
Post by Kenneth »
This problem only occurs when typing, copying and pasting doesn't occur, expect it to be fixed in the next version!
Kenneth
Post by Kenneth »
The new version 1.82 still hasn't solved the problem of flashing back after typing the Chinese character “耀” in the program.
lffs
Post by lffs »
I discovered that it’s not just one character causing the crash; in addition to "耀" (U+8000), "耄" (U+8004) also leads to a crash.
As mentioned earlier, the crash only occurs when using an input method, while pasting these characters does not cause a crash.
