Hello, how can I launch XnViewMP so that the browser is pointed to a specific location?
I use a couple of XnViewMP instances each "specialized" for a certain folder/usage and I would like to know the argument to add to a shortcut (or batch file) when launching the application to go directly to a specific folder.
(I'm on Windows 10)
Cheers!
How can I launch XnViewMP at a specific location? [Solved]
Seith
Re: How can I launch XnViewMP at a specific location?
Help > About (F1) > Command line
Seith
Brilliant, thank you!
