1.8.0: AppImage does not start under Ubuntu 24.04
cloudhopper
Post by cloudhopper »
XnView: MP 1.8.0 - 64 bit
OS: Ubuntu 24.04 - 64 bit
AppImage (XnView_MP.glibc2.17-x86_64.AppImage) crashes during startup
Effect: Message in log file: /tmp/.mount_XnView1tJGVM/usr/XnView/XnView: symbol lookup error: /lib/x86_64-linux-gnu/libVkLayer_MESA_device_select.so: undefined symbol: wl_proxy_marshal_flags
1. Download the file XnView_MP.glibc2.17-x86_64.AppImage and make it executable
2. Double click the file XnView_MP.glibc2.17-x86_64.AppImage
Actual behaviour (bug): XnView fails to start running
Expected behaviour: XnView starts to run
Re: 1.8.0: AppImage does not start under Ubuntu 24.04
No problem on a clean ubutun 24.04
cloudhopper
Fair enough, it's likely my 24.04 installation then. Perhaps it's a result of me doing a minimal install of Ubuntu 24.04 or the fact that I'm running it in a VM. An unpacked tgz archive of 1.8.0 runs fine on my 24.04 install. So, really I'm just curious as to what might be stopping the AppImage from running. But, anyway, thanks for responding so quickly.
Short addendum: I've discovered that if I preload the libwayland-client.so.0 library, the 1.8.0 AppImage runs. To do this I entered the following in a Linux Terminal session:
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libwayland-client.so.0 ./XnView_MP.glibc2.17-x86_64.AppImage
