Hi all, new here so please be gentle with me!
I heard this program has great batch support but I'm struggling. On individual pictures it's easy to adjust the basic settings like brightness, contrast, etc. and to save a set of adjustments via preset, but I'm finding it impossible to use that preset on multiple photos as a batch.
I would think this would be a basic function but I can't figure out how to do it. As a batch I'm able to make some adjustments but none of them are really the same as the single-photo adjuster (ie: no "brightness", no "contrast" slider) and it definitely doesn't include the preset I already saved.
Can anyone advise? I'm using this for work so I need to be able to apply settings to all photos. If not, I'll have to find another solution.
Limited batch adjustments?
haegx031
Re: Limited batch adjustments?
Which options are actually missing, more than Temperature and Tint?
haegx031
The second photo uploaded shows the fields i need. The first screenshot shows the batch adjustments. There is no brightness, contrast, or gamma, nor can I access my preset.
Good news -- they're hidden -- please check Add action > Map > Adjust.haegx031 wrote: Sat Sep 14, 2024 5:38 pm The second photo uploaded shows the fields i need. The first screenshot shows the batch adjustments. There is no brightness, contrast, or gamma, nor can I access my preset.
Possible 'Adjust' isn't really the best name, although it does invite one to examine the options that can be 'adjusted', can you suggest a better name?
Actually, user0, shouldn't it be Add action > Map > Adjust... with the ellipsis?
haegx031
Edit: Nevermind, I see it now lol. ignore!!! thank you so much!cday wrote: Sat Sep 14, 2024 6:06 pmGood news -- they're hidden -- please check Add action > Map > Adjust.haegx031 wrote: Sat Sep 14, 2024 5:38 pm The second photo uploaded shows the fields i need. The first screenshot shows the batch adjustments. There is no brightness, contrast, or gamma, nor can I access my preset.
Mine doesn't have map, unless I'm looking in the wrong place?
I'm in XnConvert 1.100.1, when you click Add action you should see a dropdown with Image, Map, Filter and Misc options.
I can't make a screenshot of the open menu in Linux, but here's one of the options you desire:
yeah, I would probably rename:cday wrote: Sat Sep 14, 2024 6:06 pm Actually, user0, shouldn't it be Add action > Map > Adjust... with the ellipsis?
Enhance colors... → Adjust... OR Adjust colors...
other apps use the following for the similar set of tools:
- Color correction (IrfanView, Imagine)
- Tone mapping (Affinity)
- Adjust colors (FastStone)
