MAC 1.8.0 - Crash in Preferences/View/Info
ThomasHoltWard
Post by ThomasHoltWard »
XnView: MAC MP 1.8.0 - 64 bit
OS: MacOSX 12.7.5 (Monterey) 64bit
Crashes when I try to set the Font for View/Info. (Also, View/Info is not being displayed regardless of specific settings.)
Effect: Crash
1. From anywhere... Select Preferences/View/Info
2. Click on the font name (in order to set the font)
3. Crash
Actual behaviour (bug): crash
Expected behaviour: change the selected font for the ".../View/Info"
ThomasHoltWard
Re: MAC 1.8.0 - Crash in Preferences/View/Info
New information. The "Futura" font was "turned off" on my Mac. Once I turned it on, the app no longer crashed. However, there is still no display of the "View/Info" text.
do you have tried to change font?
ThomasHoltWard
Yes, now that it is no longer crashing, I have tried changing fonts and colors and opacity. Nothing visible. It was all working in the previous release.
ThomasHoltWard
Additional Information:
Info displays correctly in full screen.
ThomasHoltWard wrote: Sat Sep 21, 2024 3:28 pm Info displays correctly in full screen.
So its good now?
ThomasHoltWard
No, it's not. It ONLY works in fullscreen (which I seldom use). In normal View mode, there is still no display of the "Info".
ThomasHoltWard wrote: Sun Sep 22, 2024 12:24 pm No, it's not. It ONLY works in fullscreen (which I seldom use). In normal View mode, there is still no display of the "Info".
even when pressing 'I' key
ThomasHoltWard
OK... I see now. In the latest release, when I first start the app, the regular View mode has 'i' off, but 'i' is on in fullscreen. Once I hit the 'i' key, they sync up again. So, I guess that's fine - it just fooled me.
Thank you for your amazing support! Case closed.
THW
