I using the batch rename function and I am trying to figure out how to keep the original name but add to the end of it. I have multiple files that are using people's names and I would like to keep the names intact. I just want to be able to add "template 1" to the end of one copy of all the files.
Batch rename - Add text to source filename
jrob86
Re: Batch rename - Add text to source filename
something like "{Filename} template 1"
Edit: Pierre was quicker than me
You can use the black arrow to choose fields to be used in the new filename ...
Select Filename in this list
Ex:
Ex:
Catalogage avec XnviewMP :
